Graph display problem
I am having trouble with a graph properly displaying a waveform I am generating. As you can see in the attached picture, the graph on the right only displays the waveform for the first 200ms. I want it to display the entire 1 sec worth of data, the same as the graph on the left.
What is going on here? I've experimented with autoscale, which, just autoscales the X axis to 0.3 sec. Both graphs are set up the exact same display options wise.
Thanks in advance.
(4,266 Views)
Show the code?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,249 Views)
(4,244 Views)
Accepted by topic author JonathonRandall
The sampling info on the VIs generating the data you're plotting is different.
Mike...
LabVIEW Champion
(4,233 Views)
Ohh right because they are just using the default values since i left those terminals unwired... That makes perfect sense, I will try fixing that.
Thank you for your help.
(4,230 Views)
