PID with Programmable Ramp Rate
I am attempting to build a temp controller with LabVIEW's PID toolkit. The controller needs to get to the correct temperature without overshoot and do it with a programmable ramp rate. However, PID does not (as far as I can tell) allow a programmable ramp rate with respect to the process variable. This must be a common requirement of a process controller. How's it done?
Message 1 of 13
(13,329 Views)
The set point is ramped.
The PID takes care of all of rest.
Ben
Message 2 of 13
(13,329 Views)
Thanks for contacting National Instruments. The PID toolkit used to have a ramp function for the setpoint. However, we have replaced it with a more versatile function called PID Setpoint Profile VI. This will let you ramp your setpoint if needed. Check out the following KnowledgeBase: http://digital.ni.com/public.nsf/websearch/125F27AC143B6AFD86256C2B0004A4DC?OpenDocument .
The response/output ramp of the PID VI itself is controlled by the PID parameters.
Hope this information helps. Please let us know if you have any further questions.
A Saha
Applications Engineering
Anu Saha
Academic Product Marketing Engineer
Message 3 of 13
(13,329 Views)
Hello
I may not talk about the same thing, but in my PID toolkit there no ramp rate related PID. The Vi dealing with the rate is actually taking a cluster of values (time, setpoint) and calculates a setpoint values by taking into account the actual time.
Is there a way to make a ramp rate ?
sorry for this question, I see that the message is several years old
regards
N
Message 4 of 13
(12,832 Views)
nitad54448 wrote:
Hello
It is just basic math.  ramp rate = (SP(n+1)-SP(n))/ (T(n+1)-T(n))
Message 5 of 13
(12,796 Views)
Hi
I am using a simple vi to make temperature profiles (sawtooth, gaussian and so on). I was questioning this comment : "The PID toolkit used to have a ramp function for the setpoint. However, we have replaced it with a more versatile function called PID Setpoint Profile VI."
N
Message 6 of 13
(12,785 Views)
I remember the old setpoint ramp VI in the PID toolkit (version 6) - i think it dissapeared when the Toolkit went to 7.1
Try this one. You can specify positive and negative ramp rates and can ramp to a final value.
Hope it helps.
David
www.controlsoftwaresolutions.com
Message 7 of 13
(12,769 Views)
hi
thanks; can you post it in 8.6 N
regards
Message 8 of 13
(12,759 Views)
I have not used this in 8.6 so let me know if you have any problems
David
Message 9 of 13
(12,749 Views)
Do you mean that you want limit contreller output? E.g if control gap ABS(SP-PV ) > [limit] is too large and you want freeze controllers output? If you need that I have a very easy solution for you. By the way why you need this kind of ramp ?
BR, Jim
Message 10 of 13
(12,732 Views)
