Overlapping of 75% means: e.g. for 1 ms integration time the sampling time is 0.25 ms
as the topic shows,  I am sure its exact meaning.   as my understanding: it looks like "downsampling" function.  a series of data will be re-sampling with dt: 0.25ms,  with a sampling number: 1ms integration time.
1) I need your confirm my understand is right;
2) for the x.lvm format stored data, how?
Thanks in advance
(3,063 Views)
when I saw express vi : re-sampling.vi, it only mention when re-sampling, how to get the secondary raw data from the first round raw data by linear, forced, sampling bar and FIR filter.    how can I  use  RMS  with integration time 1ms  block of the first round raw data as the secondary raw data?
(3,031 Views)
Hi emckiller,
I think it's very hard to follow your sentences without having any example VI provided by you…
Could you please attach a VI with some example data? Can you explain the desired output signal?
Can you explain the connection between Resampling-ExpressVI, "RMS with integration time" and LVM files?
What is "1st round raw data" and "secondary raw data"?
(3,025 Views)
its correct saying:   Time overlapping of 75 % means e.g. for 1 ms integration time a 0,25 ms time interval between successive windows.
(2,979 Views)
