Web Publishing Tool
How to use web publishing tool?For what reason it is present in Labview? I have seen a tutorial of it and connect it to given address but when I used that address on other PC which is connected with other network ,the address does not show any thing.
(6,866 Views)
the web publishing tool allows you the Publishing, Viewing and Controlling of Front Panels Remotely via  the Web server.
Since you have already seen 1 tutorial,
here is another one that you can watch 🙂 (video)
https://www.youtube.com/watch?v=WQ1aSdlvCsM
The following Link explains a lot of things with pictures.
http://digital.ni.com/public.nsf/allkb/5874283E968ADB33862573210071D43A
well, according to your problem with different networks, this might be the reason:
(picture)
Hope it helps you a step forward. And if you have further questions, please ask.
Kind Regards,
James.
Greetings and Regards,
James
(6,799 Views)
Sir it works but not on other network.I want that data or front panel should access by any one.
(6,786 Views)
The problem is not LabVIEW here, you need to understand some basic network things. Most probably your PC where you want to publish a Front Panel does not have a "real" transparent IP address which is visible from anywhere outside of your local domain. This is common thing. Like your home PC which probably does not get a fix external IP, but a dynamic local IP which you get from your internet provider.
What you need to do, is to follow this guide:
http://digital.ni.com/public.nsf/allkb/B1E9A3D78BAED949862573AD0065D4D2
Some general info about networking:
https://www.howtogeek.com/66438/how-to-easily-access-your-home-network-from-anywhere-with-ddns/
Alternative but easiest way, if you ask your internet provider or IT department to give you a fix IP address which is accessable and transparent from the whole internet. Usually this will cost you more money if you are getting access from a private net provider.
(6,784 Views)
