Open vi file with notepad
I'm currently working on getting VIs version with invoke node but it doesn't work well when I make a .EXE,
I'm now looking for information of getting the VI version by reading it like a text, I found the info manualy for 2011 and 2012 Vis but I wonder if there is a standard format for all Vis of all version of LV, a place to find the version which doesn't move ?
I've attached an exemple of one 2012 VI : we can see the 12.0.1 version : )
BR,
Mathieu
Message 1 of 12
(11,839 Views)
Could you please explain what do you exactly want?.
Means do you want Executable version or LabVIEW version in which VI is bulid?
Message 2 of 12
(11,816 Views)
Hello ManLD !
I search the LabVIEW version which is used to build the VI !
This info can be obtained with invoke node but this node is incompatible with my .exe so I'm looking for an alternative solution : look into the .VI file !
Message 3 of 12
(11,793 Views)
I think you will need to look at this link.
I appreciate your idea but there is i doubt any possibility to find the LabVIEW version checking be available in EXE.The workaround  for the process is in above link
Also if you want to know the file version of the .exe try this VI
Or try this
Message 4 of 12
(11,787 Views)
Sorry there is a misunderstood,
I'm working on a LV project which goal is to create a .exe, the .exe will be used to see version of various .vi files (and not .exe files) with a right click
I've already tried with invoke node it works when the project is in .vi but not in .exe (you can test with my .vi in LV2012)
Message 5 of 12
(11,778 Views)
I dont find your VI.
Can you please post your VI..!!
Message 6 of 12
(11,771 Views)
VI Posted, sorry had some issues with upload !
Message 7 of 12
(11,769 Views)
Have you build an executable using the following Invoke method?
Because when i run the exe of the above VI it perfectly shows the LabVIEW version of VIs.
I dont know this is what you are expecting.Smiley Indifferent
Message 8 of 12
(11,764 Views)
I think it's the same VI as mine (but in english, can you send it to me in attached file just to compare ?) my .exe is made with this node
Have you tried to load an old VI made with LV2011 or older ? Because it works for me only with 2012 VIs
Message 9 of 12
(11,761 Views)
Accepted by M.athieu.
Check the Link for the VI .
https://dl.dropboxusercontent.com/u/106333053/Get%20VI%20Version.vi
(Sorry there is an issue with the attachment of the NI discussion so i have added the Dropbox link above.
I have tried its EXE with the older versions from LabVIEW 8.2.1 to 2012
Message 10 of 12
(11,750 Views)
