Open and display XML contents
Please attach as true zip files and not as .7z.
No one wants to go and download another 3rd party zip program when there is a perfectly good one built into Windows.
Message 31 of 35
(947 Views)
Ravens,
Thanks for pointing that out. I thought 7-zip was integrated into Windows 10, obviously not. I have uploaded here as .zip files.     - John
Message 32 of 35
(941 Views)
I do not have LV16 around, but that is a generic parsing error code, and if you are following the example you are likely validating on load.  Change that value to auto or never and try again.  If you really must validate then create an indicator for the parse errors output of the Load vi and see what the problem is.
Message 33 of 35
(934 Views)
Just don't drop files on a zipped folder to replace existing files. That will corrupt the zip every time (at least I get 100% reproducibility). You might not notice until you open it again... Thanks MS!
Unzip, replace, zip.
Sad but be warned!
Message 34 of 35
(924 Views)
Thanks for the tip! - John
Message 35 of 35
(915 Views)
