Open and display XML contents
Darin, This looks perfect! I'm looking forward to tinkering with you VI and adapting it to my needs!
Thank You! -  John
Message 21 of 35
(2,127 Views)
Darin, Can you upload the VI? -  John
Message 22 of 35
(2,126 Views)
EasyXML from JKI is now free, I believe.
Message 23 of 35
(2,123 Views)
I posted a snippet, just drag it to your block diagram.  I don’t even save these example VIs, just the snippet.
If it does not work for you I will recreate the VI and post it when I get back to my computer.
Message 24 of 35
(2,115 Views)
Yes it is and also open source : https://github.com/JKISoftware/JKI-EasyXML
Epictetus
Antoine Chalons
Message 25 of 35
(2,103 Views)
Darin, The only attachment I see is the png file. I dragged and dropped the png onto the block diagram, and it turned it into a web link. Is there another file I missed somewhere?
Thanks for your assistance!  - John
Message 26 of 35
(2,094 Views)
Powell, I have installed Easy XML, thanks for the link! -  John
Message 27 of 35
(2,093 Views)
Here you go.
Message 28 of 35
(2,083 Views)
Darin,
Great! Much thanks! I will study this in detail! - John
Message 29 of 35
(2,079 Views)
Hello!
I'm trying to recreate the "Load XML with Parser API" which is an example in the "C:\Program Files\National Instruments\LabVIEW 2016\examples\File IO\XML\Parse XML" folder.
The VI I have uploaded shows the first items in the VI, a build path and a load xml file. "b.xml" is a copy of "testconfiguration.xml" which is used by the Load XML with Parser API VI.
I get  Error -2628 occurred at Invoke Node in NI_XML.lvlib:Load XML File.vi->load and parse altered test xml Saturday 5 11 19.vi
when run. All I have done is cut and past a portion of the example VI, modified how the file path and name is established, modified the file name, and truncated the remainder of the example VI I am drawing from.
Any help? -  John
Message 30 of 35
(2,067 Views)
