Open a specific browser on labView
The OS is windows 7 and the picture attached is the page of the Chrome configuration: URL= chrome://settings/defaultBrowser.
Message 11 of 20
(5,797 Views)
If you drag an url to the desktop as a shortcut, does it have the chrome icon?
Message 12 of 20
(5,796 Views)
Yes, here the example of the topic we are talking:
Message 13 of 20
(5,792 Views)
Sorry, I am out of ideas. If you open IE, does it complain that it's not the default browser? Maybe there is something corrupted in the registry or it has to do with the os language.
Message 14 of 20
(5,787 Views)
Yes, Internet explorer ask me to become the defalut browser, so it indicates that isn't it. I can assure you that the first thing that I tried was it. It is no easy...
Message 15 of 20
(5,781 Views)
No that it will help much but in the same llb
C:\Program Files\National Instruments\LabVIEW 2017\vi.lib\Platform\browser.llb
where the function Christian linked was found there is another VI called
Get System Web Browser.vi
If I run that on my machine it returns;
"C:\Program Files\Google\Chrome\Application\chrome.exe" --
Wire that to sysexec and it opens Chrome.
Ben
Message 16 of 20
(5,775 Views)
I am going to check this library
Thanks a lot.
Message 17 of 20
(5,772 Views)
I found a vi that opens the defautt browser on that librar called "open URL in default browser(string)"!!
Thanks a lot. Im going to try
Message 18 of 20
(5,769 Views)
Accepted by aitorplaza
I mentioned that in the first answer above and I thought you were testing with that one.
There is no need to dig through "libraries" and pick a specific polymorphic instance.
That VI is in the palettes! (Dialog&user interface...help")
Message 19 of 20
(5,763 Views)
Hello guys,
Sorry for open the topic again but i have a similar problem.
In fact, i need use "activeX browser control" in my labview app. The problem is that the "activeX browser control" always open IE.
Obviously i configured the default browser like chrome because the web page i wanted connected worked very well with chrome and did not work well with IE.
The device (pyrometer) gives me the ability of connect using the chrome browser.
In advance thanks very much.
Martin
Message 20 of 20
(5,632 Views)
