Open Config Data Compatibility VI 8.6
I updated a project from LabVIEW 8.6 to LV 2010 that contained extensive use of the Configuration VIs.  Upon opening the project in LV2010  I noticed that the 'Open Config Data.vi' had been replaced with 'Open Config Data ( compatibility).vi.  Same icon as the Open Config Data.vi but with a red '8.6' on the icon.
1.) What changed from LV 8.6 to 2010 that would make me need this compatibility VI?
Plus the documentation doesn't make any sense:
NI_LVConfig.lvlib Open Config Data (compatibility).vi
The Open Config Data VI was rewritten with one new output in LabVIEW 2009 and later. Replace the Open Config Data (compatibility) VI with an Open Config Data VI from the Functions palette to use the new functionality.
2.) What new functionality?  The output 'file created? is already present...
See attached..
PH
(3,341 Views)
The config function have been re-written using LVOOP.
If your VI's open without error then the new version should work similar to the old version.
Ben
(3,339 Views)
