Octave Analysis in DLL
I have many applications that might use the functionality of the SVT Octave Analysis VI.  I have wrapped the VI in a DLL to call from VC++8.0.  I am able to pass the data into the VI and it does the work but the filters NEVER settle.  I put the DLL into LabVIEW and they settled in the expected time.  I have a little more experience with dlls that are created in VC++.  I am wondering if there is a runtime library that I need to load in addition to the dll?  It worked with the LabVIEW Prop but not VC++ and the only difference was that LabVIEW was running.
(2,614 Views)
Hi Frank,
Do you have the LabVIEW Run-Time Engine installed on the computer you are using the LabVIEW DLL?  If so, make sure the version of the run-time engine matches the version of LabVIEW that you developed the DLL.  Consult the KnowledgeBase article titled LabVIEW Run-Time Engine Requirements for DLL Execution for more information.
(2,576 Views)
