09-15-2011 07:34 AM
Dear all,
I'm not able to download the Driver for the OceanOptics HR4000 Spectrometer.
The following link from NI does not work:
Could you please help me with this issue ?
Many thanks
09-15-2011 08:40 AM
Followed your link and downloaded the drivers? was no problem here ![]()
Attached is the driver for LV2010
09-15-2011 09:15 AM
Mnay thanks Corny 🙂
Well, actually my LabView version is the 8.6...
Could you please download the 8.2 Driver version and share with me ?
I'd be very grateful ! Thank you in advance 🙂
09-15-2011 09:19 AM
attached, 8.2.1 driver
09-15-2011 09:56 AM
Thank you very, very much 🙂
So far it is working well !
02-07-2012 08:41 PM
I have two questions about the HR4000 and the VI`s.
1._ I tried to run Acquire Multiple waveform.vi in LabView 2011. Every time the VI is executed it shows me the next error.
Error -1073807346 occurred at VISA Open in Ocean Optics 2000 4000.lvlib:Initialize.vi->Ocean Optics 2000 4000 Acquire Multiple Waveform.vi
2._ I opened the TR_spec_HR4000_10.vi and I found that the next subVI's are missing:
Spectral Acquisition_less_pixel.vi
HR4000_GetCoefficients.vi
HR4000_IdentifyHR4000.vi
Set configuration.vi
OOI_SetCurrentUSBSerialNumber.vi
And there is another VI's which name is not indicated in the block diagram. I add the images.
Hope someone can help me.
02-17-2012 04:32 AM - edited 02-17-2012 04:33 AM
02-03-2014 07:57 AM
Hi Zell
I am wondering if you solved your problem? Maybe you will advise me something. I am using the LabView driver for the HR 4000 spectrometer. I need to make an external triggering of it. I put external triggering in the project "Spectrometer setup" and make it run. Then I open the project "Acquire Continuous Waveform.vi" and run it as well. But there is no response from the device on external trigger. What did I do wrongly? Thanks in advance
02-03-2014 09:40 AM
Zell was here almost 2 years ago, and apparently never came back. I doubt that you're going to reach him by calling on this forum over and over. You might start a new thread and include your code with the description of your problem, or contact Ocean Optics for help, because your description of your problem does not give anyone currently on this forum any useful troubleshooting information.
Cameron
12-24-2014 05:38 AM
