read an excel sheet and selected two columns like A and C will plot as a XY Graph (X as a A column and Y as a C column)
hi sir i am read excel sheet using labview ,but unable to plot the  selected two columns like A and C will plot as a XY Graph (X as a A column and Y as a C column),so its needfull ,please find any body to sollution to the problem .i i already did some part ,it is take  too much delay
Find Below attachments
(2,976 Views)
Try something like the attached.
(Note: the way you were reading the file is just pure madness. why do you think you need to read the same file over and over from scratch using the wrong delimiter? Reading the file once is sufficient! Specify a comma as delimiter and things fall in place (except for the header)).
(2,966 Views)
When you start a thread please continue in it instead of starting a new one.
Ben64
(2,929 Views)
