06-24-2014 01:08 PM
Dear All
I am building a code that I want it to do the following:
1- output a triangular waveform with a specific frequency and amplitude.
2- then after the triangular waveform automatically output a sine wave with onother prespecified frequency and amplitude.
3- these two consecutive waveforms are supposed to be going out from the same cahnnel (AO0).
4- during the above happens and at the same time I am receiving two signals from two sensors >> calculating the difference between the two received signals >>> then outputting the difference from another channel (AO1).
My problem is the code some times is working fine and sometimes giving me the following error:
Error-50103.....
Possible reason(s):
NI Platform Services: The specified resource is reserved. The operation could not be completed as specified.
Task Name: _unnamedTask<19DB>
Please advice
p.s you can find the VI that I am talking about in the attachments
Many thanks in advance
06-24-2014 01:16 PM
The error you have shown occurs when you try to access the same resource at 2 different places. Since I don't have DAQmx installed I am not able to look into the code completely.
Since you are trying to access the AO0 and AO1 in 2 different places you are getting the error. I believe both the output share the same DAC. What is the DAQ card you are using?
06-24-2014 01:43 PM
I am using PCIe-6321 and SCB-68A.
I dont think that this is the problem because in previos (earlier) versions of my code every thing was running fine and smooth. I was outputting a sine wave from AO0 and inputting the sensors signal and making the calculations and reoutputting the result from AO1.
but now I am trying to add to the code and it works fine but occasionally it give me the 50103 error.
09-03-2014 06:40 PM
I too have experienced this occassional 50103 error. It is quite infrequent and it's difficult to reproduce for troubleshooting purposes, so I don't know if this was the fix or not, but what I did was place a time delay between the two consecutive daqmx calls (to different channels of course), using error wires to determine execution flow, and I have not seen this error show up since. Perhaps someone else has fiddled around with it more and actually found the root cause? I haven' tbeen able to sofar.
09-03-2014 07:34 PM
