floating point no. to string with same precision
I'm using 'format into string' to convert floating point no. to string. Most of the the numbers have single digit decimal so i use "%^0.1f" in the format into string terminal. But for whole nos. like 150, it gets converted to 150.0. I want to avoid this, such that the string looks exactly like the no.. What should i change?
(3,575 Views)
For whole numbers, use "%d" instead of "%^0.1f".
Certified LabVIEW Developer
(3,564 Views)
Accepted by topic author shreya005
Use %#0.1f as your format string.
Read the help file on format codes.  The # sign tells it to truncate trailing zeroes.
(3,556 Views)
Thanks a lot. it works perfectly now 🙂
(3,540 Views)
