Object Oriented programming not sure how it works
Not sure if I could find OO LabVIEW tutorials, if they are there. I used a lot of C++ OO tutorials, long before it was possible in LabVIEW, so I never did any LabVIEW OO tutorials.
There is of course the (online) NI OO course, but I don't think it's free. You\your university might have a subscription though.
Just to mention, a state machine and producer consumer architecture doesn't rule out OO. OO works well in both. I'd go for a state pattern, the OO variant of a state machine, but there are no rules for that.
IMHO, you're better of focusing on OO Analysis and OO Design, not OO Programming.
Every OO program should be preceded by OOA and OOD. OOA and OOD are more general, as in not language specific. That means more resources, and better material. You'll learn the LabVIEW OO merits as you go.
I learned a lot from Booch's Object-Oriented-Analysis-Design-Applications. The 2nd edition is a few bucks, but it misses the part on UML.
Message 11 of 20
(2,076 Views)
As weibe stated, concentrate on learning OO concepts.  Then you can figure out how to do that in LabVIEW.  In other words, learn WHY before you learn HOW.  So on that note, I very highly recommend reading The Object-Oriented Thought Process.
Message 12 of 20
(2,072 Views)
Yes, also very good.
Message 13 of 20
(2,063 Views)
I know Object Oriented Programming in C++. So I think I know the concepts. Thats where my problem comes, in C++, I create a private data it is accessible through objects and a method that lets you access the data. I try this in LabVIEW where I create a private data which is inside the cluster of the class and I try to access that using subVIs nothing is happening. Also I know inheritance and polymorphism in C++. But I will never use C++ because I dont want to be a C++ programmer. I want to be a LabVIEW programmer. So I am trying to learn Object Oriented Programming in LabVIEW and MATLAB for my career. But I have a long way to go before I start OOP in MATLAB. But I need to get good in LabVIEW OOP now atleast the basics, command pattern and actor framework, they are just too complicated. The remaining basic stuff in LabVIEW OOP that is what I want to learn. How to access data using method VIs in OOP. This is my goal for now. If anyone could guide me the path to achieve this, it would be helpful.
Message 14 of 20
(2,054 Views)
Accepted by govindsankar
The OO concepts are the same in LabVIEW and C++. The biggest issue you are probably running into is that LabVIEW is a by-value language. If you branch a wire in LabVIEW you have effectively cloned the data. Updates on the two branches of the wire are not reflected on the other branches. You can work around this by using by-reference objects. As mentioned earlier your cluster of private data in the class definition would need to contain a Data Value Reference (DVR) to your data. A DVR is like a pointer in C. It simply points to the data. With a DVR you only have one copy of your data so updates will be seen by all branches of the wire. Of course, you can run into race conditions with operations occurring in parallel.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 15 of 20
(2,044 Views)
Which is exactly why you can use the Inplace Elements Structure with a mark to allow concurrent read access on later versions of LabVIEW.
"Should be" isn't "Is" -Jay
Message 16 of 20
(2,033 Views)
In C++ (I'm no expert), it works exactly the same as in LabVIEW. In C++ when you pass a calss by it's value to a function, a 2nd function will not get the update unless it's passed through the return value. But since C++ only allows one return value, often objects are passed by reference. That sill doesn't work well in parallelly executed parts (threads) as the objects are not automatically suited for asynchronous access.
IIRC, the new C++11\14 standard has much better options for specifying the exact behavior or passing values, with the event of L-Values. There are now L vaues, R values, values, pointers and references. I thing at the moment libraries are recommended to not use by reference objects anymore, allowing more compiler optimizations. But I could be wrong.
Good choice. I think LabVIEW OO might actually be harder coming from a C++ background.
You're current problem isn't something I'd recommend for a beginner. It is typically something beginners run into though.
Command patterns aren't that complicated. Most patterns are really simple. You'll probably use only two or three. Different reasons for using inheritance or containment are sometimes even labeled as separate patterns. Some are so basic, you'll either use them without knowing, or learn about them and use them (or both in random order).
The actor framework is build on the actor pattern. I agree that it's complicated. Let's not go there.
If you write private data in method A, you will be able to read it in method B. As long as method B acts on the same object. As soon as you split the wire, you get two objects. OO isn't different then any other object. Even splitting a reference will get you two references, but they point to the same data.
The problem you're facing is this isn't really related to OO. If this data was a cluster, or a number, string, array, or whatever, you'd have the same problem. You though OO would fix this, it doesn't. It could help though, as you have more options with OO. You can make a class, and make a singleton child. Or make a DVR-ed child. Or put the object in a global\FGV\private global. Or put the private data in a DVR. These solutions are not related to OO per se. They are the solutions that solve asynchronous data access in general.
We gave quite a few pointer. I'd go for passing the objects in a queue, event or channel wire.
I think besides OO, there might be some things you'll learn from this: labview-basics.
If you (or your company\uni) has a SSP: self-paced-training
And of course (not free): Object-Oriented Design and Programming in LabVIEW
Message 17 of 20
(2,014 Views)
I've used OO in LabVIEW since 1998, and it started off as by reference, but it was an add-on to LV.
When LV 8.2 came out, it got native support by only By-value OO support.
So we had to add by-reference support on-top of the native OO.
Many people are using OpenGDS for this: http://opengds.github.io/
It makes it easier to go from other OO languages into LabVIEW since it by reference as text based languages uses.
The OpenGDS is a tool that helps you create classes in LV. It can create By value and By reference classes.
There are some training videos and other info here:
https://forums.ni.com/t5/GDS-Goop-Development-Suite/gp-p/5050
Videos:
http://www.youtube.com/watch?v=UcUj_Gl1JdI
https://www.youtube.com/watch?v=hdcHYS_ZFr8
http://www.youtube.com/watch?v=_BvIiU2VMAU
http://www.youtube.com/watch?v=ZWeO_wPe-VQ
http://www.youtube.com/watch?v=OunqB9UdR6o
http://www.youtube.com/watch?v=VncaD_pKe_s
http://www.youtube.com/watch?v=i77lHDIMs_s
Message 18 of 20
(1,990 Views)
No, most text based languages do not use by reference objects.
In C++ for instance, objects are not by reference.
C++ Objects are often passed by reference, but that doesn't make the objects by reference. In LabVIEW, you can make an object, and pass it by reference (e.g. a DVR). That doesn't make the object a by reference object.
C++ and LabVIEW objects are the same. It's just that passing objects by reference in C++ is facilitated in a more native way. You can simply decide when you call a function if you pass by value or by reference as a feature of the language. In LabVIEW, you can do that too, but it's less convenient.
Java does pass objects by reference as only option. So in Java, it makes more sense to say objects are by reference (although strictly speaking they are really just passed by reference). Pretty sure in most other text languages objects are not by reference.
Message 19 of 20
(1,980 Views)
And this is why I personally like LabVIEW.. Pointers to pointers to references of the data of an object.... Bull Doody!
The object is the wire. the data is there, DVRs also exist if you cannot deal with how LabVIEW did that memory management for you. Its abstracted away from the user because users make mistakes!
Message 20 of 20
(1,954 Views)
