Number array to boolean array
I have a 1D array of 16 bit integers (they are all 0 or 1's).  I would like to convert it to boolean array but when I try to use num to array function a broken wire appears:
Message 1 of 8
(8,474 Views)
Accepted by topic author RFeng
Hi RFeng, I think that function you are attempting to use is for converting 1 numeric (not an array) to its binary representation. You can just use the "not equal to zero" function to convert your numbers into booleans.
Message 2 of 8
(8,469 Views)
It looks like you are using the Number to Boolean Array primitive.  This converts a *single* number to an array of Booleans.  One way of converting an array of integers to an array of Booleans is to just pass it to the Greater Than 0? primitive.  Any value in the input array that is greater than zero then results in a TRUE value in the output array.
Message 3 of 8
(8,454 Views)
I use "greater than zero" just because my mind accepts "greater than zero" a little more readily than "not equal to zero".  I guess that's because it's a tiny bit less ambiguous.
Bill
CLD
(Mid-Level minion.)
Message 4 of 8
(8,431 Views)
I still (partially) recall some language or environment I used way back in the 90's (maybe even the 80's ?) where booleans were typically signed ints with a -1 value (all bits set high).  As I recall, any non-zero integer value would evaluate as True, positive or negative alike.  A "greater than 0" comparison would have wrongly missed all the built-in boolean constants.
So my habit would be to check "not equal to 0" so I don't have to check to see whether the int is signed or unsigned.  (I'm pretty sure this came up in another thread not all that long ago, but I couldn't find it easily just now.)
-Kevin P
Message 5 of 8
(8,410 Views)
-Kevin P
That was something I never knew!
Bill
CLD
(Mid-Level minion.)
Message 6 of 8
(8,387 Views)
@Kevin_Price wrote:
So my habit would be to check "not equal to 0" ...
Exactly. This is the only correct interpretation of the definition:
Quote from here:
"LabVIEW stores Boolean data as 8-bit values. If the value is zero, the Boolean value is FALSE. Any nonzero value represents TRUE."
Message 7 of 8
(8,380 Views)
I know that is the case in C/C++.  LabVIEW follows the same suite.  I can't say about any other language.  So, yes, "Not Equal To Zero" is the proper operation.
Message 8 of 8
(8,372 Views)
