Normalize plots
Hi all,
I am trying to normalize plots. I have an accelerometer giving me three axis of data and a proximity sensor giving me data for the rpms of a motor. I am currently using a measurement computing DAQ which runs the NI ULx driver. My overall goal is to be able to see the vibrations as a function of rotational speed.
Message 1 of 8
(6,518 Views)
If you could save for LV 2012 or earlier I can take a look. It seems like a very large file size for a single VI. Can you not just divide by the maximum value of the curve to normalize it?
Message 2 of 8
(6,469 Views)
Hi jhealey,
Could you elaborate on what you mean by normalizing the data in this context? Do you intend for each plot to have the same x- and/or y-axis limits? Are you expecting your data to always fall within a certain range?
Tom D.
Staff Software Engineer
NI
Message 3 of 8
(6,435 Views)
What you look for are order analyses, and you want to resample the data to even angle instead of even time. Have a look at the sound and vibration modules,  it all there 🙂
One pulse per revolution is not that much...   but it depends what you are looking for and how your system behaves....
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 8
(6,413 Views)
Tom,
I like my plots to each be a rpm versus vibrations data. Basically showing that as your speed increases, so does your vibrations.
Message 5 of 8
(6,403 Views)
Hi jhealey,
How are you planning on calculating vibration? I am guessing it is based on the x-, y-, and z-axis coordinates somehow?
Tom D.
NI
Message 6 of 8
(6,354 Views)
Tom,
My accelerometer gives me readings for the X, Y, and Z directions. I have converted the voltage outputs into units with gravity. I bundled the readings from each to show one plot with three readings. Is there any way to really make this an rpm vs vibration plot? Preferably on one plot but if one for each direction is needed, that will work for my application.
Message 7 of 8
(6,345 Views)
You want to plot RPMs on the y-axis and vibration on the x-axis? It sounds like you already have the RPMs array. For the vibration array, you could take the magnitude (sqrt(x^2 + y^2 + z^2)) and plot along the x axis. You can either bundle into a cluster, or use the re/im to complex function, and then wire into an xy graph.
Message 8 of 8
(6,339 Views)
