New Vi Object - Replace Array Subset, resize and wires Script
Hi all,
I can create a Replace Array Subset.
my problem is:
I what to resize it (add more inputs ) and wire the in and outputs.
Pls help!
i want to generate semthing like this:
(3,742 Views)
There are many array functions to choose from.
You haven't really given us much information because you say "i want to generate semthing like this:". If that's what you want, there you go.
If you want to replace array subset, but also resize, you can use the Insert Into Array as well.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,719 Views)
Accepted by topic author mogergog
There are two methods of the GrowableFunction class, AddChunk and RemoveChunk, which can be used to add or remove X input chunks from the top or bottom of the node.
(3,686 Views)
