 IC_designer
			IC_designer
			08-11-2011 10:34 AM
Hallo all who read this thread,
I am trying to program newport optical power meter 1936-c in Labview but could not communicate with the instrument over USB connection.
I have installed the drivers necessary for the operation of the optical power meter from newport website:
ftp://download.newport.com/Photonics/Power%20Meters/x936-C_x1928-C_1918-C_R_%20Software_Suite/
I am running windows XP service pack3, 32 bit version.I believe I have installed the correct version of the driver for communication with the device over USB connection.The application software provided by the newport runs correctly, and I am sending and receiving the commands,but when I try to connect to the power meter using Labview sample programs provided by newport, I am not able to send or receive anything,instead the program seems to run an infinite loop and i get no reply until I have to restart the program.I am using Labview service pack 9 and I have tried all the sample programs 7.x ,8.x and 2009 version,but unfortunately no progress(:
I am trying to send a power command PM:Power? to the power meter to get the power.But it doesnot give anything.
For this puspose I have found somewhere on the forum this file: NP_GeneralDrivers_LV8.llb (file attached).I have used sample query program with this file but still the device is not responding .I dont know how to proceed now, as I have only basic knowledge of Labview programming.
I have attached some screenshots of the program I am currently using:
I would highly appreciate if someone could help me.
kind regards,
shami
 kuttus
			kuttus
			03-09-2012 04:08 AM
I am also trying to interface power meter 1936 C. I am using the labview sample programs (directly without any modification) given in the newport CD. I am attaching it below. But the USB driver file I could not find. It shows an exclamatory mark in device manager. Also when I run the code it shows that not able to open the device. Please help me to fix this problem
 smercurio_fc
			smercurio_fc
			03-09-2012 07:22 AM
Please read the documentation that comes with the software. From the ReadMe:
In order for a computer to communicate with the 1830-R, 1918-R, 1928-C or 1936-C/R,2936-C/R a full install of the computer interface software is needed.
The "computer interface software" is available on the Newport site, not from National Instruments since Newport makes the meter.
 flanguy
			flanguy
			05-22-2014 02:19 AM
Dear all,
I have the same problem as described here above.
I have installed the required drivers. The instrument is indeed recognise. But I am unable to get any data (even the IDN !)
Was someone able to get some data from its 1936-c ?
Thanks in advance,
Fabian
 Rswint
			Rswint
			08-11-2014 02:25 PM
I have the same problem (Newport 2936C actually) - can't see the USB device in e.g. NI Max under "Devices and interfaces"
I've installed the newport device drivers: Computer Interface Software v3.0.2 from Newport ( http://search.newport.com/?q=*&x2=sku&q2=2936-R ).
I even upgraded the intrument's firmware.
The drirver Seems to install OK - I can see the device (Newport Power Meter) listed under the Wndows Universal Serial Bus Controller list, yet no listing in NI-MAX
I've tried this with 3 different computers (XP & Windows 7, LabVIEW 2012 & 2013) now to no avail.
Any suggestions?
Reuel
 Dennis_Knutson
			Dennis_Knutson
			08-11-2014 02:42 PM
 Rswint
			Rswint
			08-11-2014 02:52 PM
Thanks for the thought that USB devices shouldn't appear in NI MAX.
However, at
http://www.ni.com/getting-started/set-up-hardware/instrument-control/usb-connect
there is an illustration of finding Tektronix USB devices in NI-MAX. Should this work for a Tektronix device and not a general USB instrument??
The Newport sample LabVIEW codes are also failing to find the instrument.
Reuel
 Dennis_Knutson
			Dennis_Knutson
			08-11-2014 03:02 PM
 550nm
			550nm
			09-11-2014 07:19 PM
Hi Shami,
Not sure if it's too late to mention that it's possible to communicate with the Newport 1918, 2935, & 2936 C/R series power meters using VISA.
Use the NI-VISA driver Wizard (Programs\NationalInstruments\VISA) to create a VISA device-driver, then, in MAX, the device will appear as a RAW USB port.
The two attached infs - for XP and Win7 - were created this way.
I think usbdll.dll (the "Jungo" driver) limits communication to one PM per application. Also, with usbdll.dll, I encountered a 2sec USB-related delay/timeout (for which there may have been a workaround). Using VISA avoids both these issues, at the expense of having to write your own LabVIEW drivers.
Hope it helps!
 hhaaii
			hhaaii
			12-21-2014 02:16 PM
I recently found that the USB driver provided in newport's v3.0.2 package doesn't work for WIN8.1. Newport supporting team confirmed it and told me that I can use the USB driver included in the software package for model 8742 (http://assets.newport.com/webDocuments-EN/images/PicomotorApp_2.0.4.zip) instead which is a new updated version. I tried and it works for me.
