Copying Probe Data To Notepad
Hi everyone,
A lot of times when debugging code I want to copy probe data to notepad (text file).  I right click on the probe data I want to copy and select "Copy Data" but when I try to paste the data into a text file it doesn't paste.  Is there a way to do this?
Thanks so much!
(6,045 Views)
"Paste" the data from the probe watch window to a blank vi Block diagram rather than notepad..
Actually that's probably a little known feature of the PWW.  But it works wellSmiley Surprised
"Should be" isn't "Is" -Jay
(6,038 Views)
Thanks Jeff Bohrer.  Sometimes though you want to send this information over to someone else while trying to debug code.  Is there a way to pull the data from the Probe window and into notepad?
(6,006 Views)
Not that I am aware of but, That's what gotomeeting is for.  get someone esle right on your machine
(5,979 Views)
You might vote for this idea - Right-clic​k -> Copy Data should copy TEXT data
Jim
(5,953 Views)
Hi all,
I'm no expert and as I regularly rely on the many good folks on these forums to help me out, I thought I'd take the opportunity to share how solved this as I don't often have much to contribute.
My approach...  "Copy Data" from a right click on the probe...  paste it into blank VI... wire it to "Write to Spreadsheet File VI"... gave it a filename...  and run it.  Then opened the resulting file in Notepad and begin copying and pasting to your hearts content.
Cheers, Iain
(5,382 Views)
