Need help regarding teststand and report generation
How to get report in teststand in xls format that takes data(Tables and Graphs)from LabVIEW code and it has to append data each time I run the code in a sequence? I am doing some test X on pin number 1 of an IC which generates some table of data and a graph and I want to do the same test on rest of the pins of an IC which also generates a table of data and a graph. I am calling these vis in teststand one after the other. Now I want to generate a report which sholud include all tables and graphs with headers in excel format.
(2,304 Views)
You'll be better off posting your question to the TestStand board.
(2,298 Views)
