save image using case structure
I want my program to save the image displayed on the "Processed image" in a  specified location when I press the boolean button. It is showing an error when executing. How to fix that?
(2,669 Views)
well in you subvi you destroy the image buffer (with the IMAQ dispose) so when the main VI tries to save the image to file it fails to do so because the image data doesn't exist anymore. you need to remove the image dispose VI of the image you want to save and place it in the main VI after the save to file.
hope this helps
Epictetus
Antoine Chalons
(2,658 Views)
