Need help doing Trapezoidal Chart Profile
I'm a beginner in LabVIEW but I'm trying to do a simple trapezoidal chart profile to find the final velocity by using 6 inputs; current velocity, target position, current position, acceleration/deceleration, change in time and maximum velocity. So if u reply, please give a concise explanation and description of the program. Thanks! 🙂
Message 1 of 9
(3,838 Views)
Hi Star,
I would guess the "final velocity" is the last value of the "current velocity"…
So what is your exact problem - and what did you try so far?
(Mind to attach your current state of the VI?)
When you don't attach any VIs (aka "program") we cannot give explanations…
(When you want to hire someone to do your work you should post in a different board!)
Did you notice the "Training" section in the header of the LabVIEW board?
Message 2 of 9
(3,825 Views)
My teacher gave me this assignment but I'm totally confused on how to start. I know by using a graph chart we could increment until it reaches the maximum velocity( the line would increase, then stays horizontal ) but I do not know how to continue from there. He gave me the 6 inputs but I only managed to use maximum velocity and current velocity. During the constant acceleration stage, I've been told that the robot moves to a specific destination, which is its current position, but will then decelerate to its target position, which reaches its final velocity. So, I'm wondering if the final velocity is just zero?
Well, I wasn't aware of the Training section, however, I'm not entirely sure if they would teach me "Trapezoidal Profile". And also because I'm not entirely a beginner.
Message 3 of 9
(3,795 Views)
Accepted by StarStrike21
Hi Star,
Why don't you ask your teacher? Or your classmates?
When you go through that Training you will learn how to handle DAQ data (aka a "signal"), how to collect that data in an array (or waveform), and how to analyze that data. Please try to stay away from the term "Trapezoidal profile", but think about "reading and analyzing a signal"…
Message 4 of 9
(3,784 Views)
My classmate is using the formula node to do the coding but I do not understand C+. And also because technically, I already did DAQ since I did Sawtooth & Horizontal Charts but I couldn't do Trapezoidal profile.
Message 5 of 9
(3,778 Views)
There are several formulas to use, which are v = u + at and v^2 = u^2 + 2as. Also, how do I get the time from the graph chart.
Message 6 of 9
(3,772 Views)
Hi Star,
A chart is an indicator, so you will not get any "time" from a chart.
You should get "time information" from your DAQ device!
Message 7 of 9
(3,753 Views)
Okay. I think I'm almost done with the VI. Turns out its pretty much arranging the formulas in a certain order. But thanks anyways.
Message 8 of 9
(3,747 Views)
https://en.wikipedia.org/wiki/Equations_of_motion
Message 9 of 9
(3,739 Views)
