SubVI and table/array
Is there any way to get a table or an array from a subvi??? Pls
In my project there's a subVI where I have a table with random numbers, I need to get all those values and write them in another table on my main project... I prefer table, but it can be using array as well...
(3,039 Views)
Hi Douglas,
setup the connector pane of the subVI as needed and use wires to get data from subVI to MainVI…
(This is pretty basic LabVIEW stuff: did you notice the Training section in the header of the LabVIEW board?)
(3,031 Views)
A table isn't a data type... You can pass a reference to the table, or indeed pass the 2D data of the table. Use Strings[] (IIRC) property of a table to get the data, and pass as an indicator connected to the connector pane.
(3,005 Views)
