Need Solution for Sub VI Missing
Hi all,
I am new to this Labview environment, Could you please help me to solve the issue am facing in labview program. Recently i got a sample application code when i open this file i got some errors like
Poly VI 'MB Serial Master Query (Poly).vi': Sub VI is missing
Sub VI 'ADO Connection Create.vi': Sub VI is missing
Further i am not able to run the program, Please guide me to solve the problem. I don't know this issue may be a small one but am not able to give a correct solution.
Awaiting for your valuable feedback.
Santhoshkumar.
(7,241 Views)
For Modbus you are probably missing this library: https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
Regards, Jens
Kudos are welcome...
(7,209 Views)
The ADO vi is from a database toolkit. Probably NI's database connectivity toolkit.
(7,206 Views)
Already installed this library even though this error might occur. Is there any alternate solution to solve the problem?
(7,191 Views)
If you are sure it's installed (and where), LabVIEW might look for the files in the wrong place. When lv searches for the vi's, press the browse button and navigate to the vi manually. You might need to repeat this a few times. When all files are located, and the project is saved, next time you should not have to do it again.
Another option might be that the original programmer made these vi's and store them in the libraries. That means they are simply lost... It's unlikely though, most of us don't bother making polymorphic vi's for one time use.
(7,186 Views)
About Modbus. You should download this library https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019 (download link https://download.ni.com/pub/gdc/epd/nimodbus121.zip)
It contains a "NI Modbus.llb" library that contains poly VI 'MB Serial Master Query (Poly).vi' and others.
(6,563 Views)
Thank you very much for the File sharing. It helped me fixed the issue just now.
(3,318 Views)
