Naming cases in the case structure
Hey all,
I'm currently trying to create a case structure using enum constants to tell it what state to go to, my problem is LabVIEW keeps changing the names of my cases to 0, 1, and so on.
Everytime I type in anything like "initialize" it just changes it back to whatever it was before. Is there any reason for this?
Thank you,
-Jake
Message 1 of 12
(4,585 Views)
Create a typedef of your ENUM and use that for all instances of your ENUM. THat will keep all copies of it up to date and in sync, including the case structure.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 12
(4,584 Views)
Are you sure you are actually using an enum and not a ring control?
Message 3 of 12
(4,568 Views)
If your case structure is showing numbers instead of text, you are definitely not using an enum.  You are using a ring control.  Even though you can associate text with a ring control, it isn't the same as a true enum.  A ring control uses the index number for case selection.  An enum uses the actual text for case selection.
- tbob
Inventor of the WORM Global
Message 4 of 12
(4,563 Views)
But if you mix typedefed with non-typedefed ENUM you will see number instead of labels as well.
Mark Yedinak
LabVIEW Champion
Message 5 of 12
(4,559 Views)
How do you mix enums?
Message 6 of 12
(4,547 Views)
Easy.  Create enum.  Put some constants inside a few cases. Change the enum.  Make more constants.
Then think, "Oh, I should have made it a typedef!"
Been there, done that.  Hopefully smarter now.
Lynn
Message 7 of 12
(4,545 Views)
Okay, so mixing non typedef and typedef'd enums into the shift register of the loop.  ??
Message 8 of 12
(4,542 Views)
Lynn
A painfull lesson we all learn ( once)
"Should be" isn't "Is" -Jay
Message 9 of 12
(4,541 Views)
____________________
Yes.  That will do it.
Lynn
Message 10 of 12
(4,536 Views)
