Name file with spreadsheet
Hi, I save the data with "Write to Spreadsheet" and I know that I can save it in a created file with a path or create a new.
I need name and create a file for every day automaticlly. If is Monday, the name of file will be Monday and save the data un this file.
How can I make it?
(3,011 Views)
Hi rvenge,
The simplest way to get this automatically is to use the Get Date/Time String function with the date format input set to "long"- use the "date string" output, which will give you the day of the week etc.
You can then construct a file name/path using this and the functions in the String and File I/O palettes.
Tom L.
(3,003 Views)
If you are using the Write to Spreadsheet File, then all you have to do is change the file name to write when the day changes.  You can get the day of the week with the Format Date/Time String function with a %a wired to the time format string.
(3,001 Views)
Thanks!, I understand it. I can create a new file with "Open/Create/Replace File" but I don't know where conect the string to name the file.
(2,995 Views)
Accepted by rvenge
If you are using the Write to Spreadsheet File, you don't use the Open/Create File.  Use the Build Path to append the file name to the desired folder and wire the new path to the Write to Spreadsheet File VI.
(2,982 Views)
