Naive Algorithm for Pattern Searching
Is anyone doing this in LabVIEW?
https://www.geeksforgeeks.org/naive-algorithm-for-pattern-searching/
just curious.
Message 1 of 11
(3,143 Views)
Accepted by topic author _Phobos
Use the "Match Pattern" primitive.
Message 2 of 11
(3,116 Views)
Just another possibility....
Message 3 of 11
(3,102 Views)
i overlooked (n-m) +1 ... 🙈
Message 4 of 11
(3,085 Views)
That works! Thank you!
Message 5 of 11
(3,042 Views)
I have a couple questions. If LabVIEW is zero indexed, I understand why the last search result is 12. What about 9, the second search result? Shouldn’t the output be 0,8,12 if LabVIEW is zero indexed?
The original GeeksForGeeks example output is: 0,9,13.
Message 6 of 11
(2,990 Views)
Maybe there’s a typo in the generated output? The original “calculated” output is 0,9,12.
Message 7 of 11
(2,987 Views)
Your example is also 0-indexed. With the found indices at 0, 9 and 12. Why do you think the second index should be 8?
Message 8 of 11
(2,929 Views)
Look further down the page. The Output lists 0, 9, 13. This is not consistent with 0, 9, 12. I think there is a typo in the Output.
Message 9 of 11
(2,920 Views)
The 9th element in a zero-indexed sequence would be 8. The 13th element in a zero-indexed sequence would be 12.
Message 10 of 11
(2,916 Views)
