Naive Algorithm for Pattern Searching
Is anyone doing this in LabVIEW?
https://www.geeksforgeeks.org/naive-algorithm-for-pattern-searching/
just curious.
Message 1 of 11
(2,991 Views)
Accepted by _Phobos
Use the "Match Pattern" primitive.
Message 2 of 11
(2,964 Views)
Just another possibility....
Message 3 of 11
(2,950 Views)
i overlooked (n-m) +1 ... 🙈
Message 4 of 11
(2,933 Views)
That works! Thank you!
Message 5 of 11
(2,890 Views)
I have a couple questions. If LabVIEW is zero indexed, I understand why the last search result is 12. What about 9, the second search result? Shouldn’t the output be 0,8,12 if LabVIEW is zero indexed?
The original GeeksForGeeks example output is: 0,9,13.
Message 6 of 11
(2,838 Views)
Maybe there’s a typo in the generated output? The original “calculated” output is 0,9,12.
Message 7 of 11
(2,835 Views)
Your example is also 0-indexed. With the found indices at 0, 9 and 12. Why do you think the second index should be 8?
Message 8 of 11
(2,777 Views)
Look further down the page. The Output lists 0, 9, 13. This is not consistent with 0, 9, 12. I think there is a typo in the Output.
Message 9 of 11
(2,768 Views)
The 9th element in a zero-indexed sequence would be 8. The 13th element in a zero-indexed sequence would be 12.
Message 10 of 11
(2,764 Views)
