NIPBCFK.sys
I am having my computer post a Unknown Device Error in the System Devices . When you look at the device it states that it is a National Instruments device with the following files:
NIPCFK.sys Version 1.1.1.f0
NIPXIBAF.sys Version 2.5.4f1
NIPXIBRC.sys Version 2.5.4f0
I am unable to update the drivers or clear this error from the list.
Can anyone explain to me what this error is and how I can correct it?
Message 1 of 8
(6,877 Views)
See here for an indication of what those drivers are: http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/What-are-driver-nipbcfk-sys-nipxibaf-sys-and-...
Did you recently make any hardware changes or install/uninstall software?
Message 2 of 8
(6,873 Views)
No new software.....I did go thought and do a repair on the Labview 2010 to see if that fixed the problem....it didn't
Message 3 of 8
(6,871 Views)
Hi Blane,
What is the current software and hardware of your setup?  Also, which version of PXI Platform Services are you running?  A possible upgrade to PXI Platform Services 3.0.1 could help re-associate the files that you are listing with their appropriate directory and clear out the error.
Marcus
Marcus M.
PXI Product Support Engineer
Message 4 of 8
(6,859 Views)
Thanks for the suggestion but this didn't fix my problem. I am still getting a error from this device.
Running Windows XP professional, Labview 2010 and Diadem 2011. I am not sure but it appears that the registration database is not associating the files correctly.
Bill
Message 5 of 8
(6,847 Views)
Hi Bill,
Which device are you specifically referring to?  I'm assuming it's a card inside of your PXI chassis?  Could you also let me know what other hardware you are using?
Marcus
Marcus M.
Message 6 of 8
(6,835 Views)
Marcus,
There is no chassis attached to this computer. This is the computer I use to do my Labview Development on and presently do not have any chassis attached to the computer. The only devices I have attached to this computer are a USB wireless mouse and and USB monitor.
Bill
Message 7 of 8
(6,829 Views)
Hi Bill,
Would it be possible for you to attach a picture of your device manager, or just the portion that lists the errors, along with a MAX Report so that I can compare the NI software that you have installed to the error that you are receiving?  Have you ever used this computer to communicate with a PXI chassis before?
Thank you for your help.
Marcus
Marcus M.
Message 8 of 8
(6,811 Views)
