NI USB-8472
Hallo ich bin bi newcomer und arbeite seit april mit labview, ich habe einen ni usb-8472 adapter und möchte telegramme senden und empfangen. Ich habe den NI-Can installiert, kann aber nicht mit Labview kommunizieren. Der Adapter hat immer 5 V an Pin 2 und 0 V an Pin 7.
Ich habe versucht, den Adapter mit dem Geräte-Manager und NI Max zu konfigurieren, aber ohne Erfolg.
Kann mir jemand helfen, wie man den Adapter konfiguriert und dann in Labview implementiert?
Ich möchte einem Kandidaten Testtelegramme schicken und diese beantworten
Vielen Dank
(2,761 Views)
Accepted by topic author micmai
Hi Mirmic,
this is English speaking forum.
When writing your questions in German, try to use German NI Forum page, where you can reach bigger audience.
https://forums.ni.com/t5/Deutschsprachige-Community/ct-p/DEForum?profile.language=en
You can also express your questions in English here.
Hope this helps.
Patrik
Patrik
CTA, CLA
Helping (sharing) is caring!
If the post was helpful - Kudo it.
If the post answered your question - Mark it as Solution.
(2,671 Views)
Hi, I'm bi newcomer and have been working with labview since april, i have a ni usb-8472 adapter and would like to send and receive telegrams. I have the NI-Can installed, but I can not communicate with Labview. The adapter always has 5 V at pin 2 and 0 V at pin 7.
I tried configuring the adapter with Device Manager and NI Max, but to no avail.
Can someone help me how to configure the adapter and then implement it in Labview?
I would like to send test telegrams to a candidate and answer them
Many thanks
(2,663 Views)
Accepted by PatrikKaranNI
thanks for updating this into English.
Regarding your issue, I found similar post about the same CAN card, which can point you to solution of your issue:
https://forums.ni.com/t5/Industrial-Communications/NI-USB-8472-CAN-communication/td-p/3578061
The voltage on your pins is correct, PIN 7 is for High-speed CAN, while your card is Low-speed (voltage on PIN 2)
You can also check NI CAN SW and HW manual on the following link:https://www.ni.com/docs/en-US/bundle/ni-can-hw-sw-seri/resource/370289t.pdf
Hope this helps.
Patrik
CTA, CLA
(2,621 Views)
