07-23-2009 04:13 AM
hello NI,
i have labview touch panel module in my PC, i am trying to use Thirdparty touch panel PC with Windows CE 5.0 with ARM 9 processers. read the Getting started with NI TPC. where they mentioned that
if accessing with thirdparty touch panel, need to be install the NITPC service.cab file in the Touch panel target.
i took these file from labview8.6/pda/utilities/arm 9
but when i am going to be install in the touch panel target its shows "NI TPC service 1.0 was not installed successfully. Please run setup again"
i tried to installed in the touchpanel target application data folder and documents.
please find this attachment
07-23-2009 04:46 PM
Try this:
07-25-2009 01:49 AM
Hello Adnanz,
Thanks for your reply. i tried as per the document which you sent. still i cant able to install the NI TPC service on the target. i tried to rename the folder name in the target it doesnt allow to rename, after i created a folder named as "HardDisk" then also its not intalling.
i am getting same error.
can you give me a suggesstion.
on my target i have My Documents, profile, Application Data, Program Files, Temp, Windows these are the available folders in my Touch panel PC.
I have ARM 920T processers, 32080KB RAM, OS: Windows Ce 5.0 (Build 1400)
I have labview 8.6 version and TPC module 8.6 OS: XP
07-27-2009 01:36 AM
07-27-2009 07:23 AM
08-17-2011 12:59 PM
The NI TPC touchpanel CAB file would not install on my third-party touchpanel (IVC NP880S) until I plugged in a USB memory stick. The USB stick shows up on my Wince 5.0 device as HardDisk. Apparently the installer wants to see a HardDisk folder as a target or it errors out.
