PCMCIA connectivity to remote controller (compact Field point)
I have an acoustic emissions data acquisition board (Micro DiSP from Physical Acoustics), which can be connected to a Laptop using a PCMCIA connection and the acoustic data can be retrieved by the laptop using labview vi's provided by Physical Acoustics.
However, our intention is to use an Compact Field point (cFP2220) to communicate to the Micro DiSP board and retrive the data. Does anyone know how can a PCMCIA interface be connected to cFP 2220? You ideas will be appreciated.
Thank you
Ravi
(2,338 Views)
rpula,
depending on that Physical Acusitcs API you may be able to communicate with the Compact FieldPoint 2220 through the FieldPoint read and write 🙂
Sam S
(2,324 Views)
