NI MAX could not launch
I have installed LabView 2015 and when I try to open NI MAX, I get an error "NI MAX could not launch because  the required library mxrmcfg.dll failed to load" as attached picture. I've completely uninstalled LabView and re-installed, but I got the same error. Can someone please help me!?
Message 1 of 48
(19,761 Views)
Has LabVIEW and MAX ever worked on this machine?  It is not clear if something "broke" or "never worked in the first place".
Have you installed any Device Drivers?
Message 2 of 48
(19,705 Views)
Force reintall the NI MAX or
The issue may be NI MAX Corruption, try to reset the database. This may solve ur problem
AB
Kudos are Accepted
Message 3 of 48
(19,688 Views)
Hi Bob. In fact I don't know if it already worked. I have installed NI daqmx and then tried to open NI MAX and didn't work. Labview works properly.
Message 4 of 48
(19,672 Views)
AB, I'll try reset database
Message 5 of 48
(19,670 Views)
I tried to reinstall MAX and reset database. Nothing works. NI MAX with the same error.
Message 6 of 48
(19,642 Views)
Maybe reinstall OS and check!!!
uday
Message 7 of 48
(19,636 Views)
Hi
I've exactly the same problem. I also tried to :
1) Repair MAX
2) Force the reinstallation
3) Get the dll from another computer
Without success...
I think reinstall the OS is a little bit excessive no ? I really appreciate if someone has another idea than buying a new PC ...
Message 8 of 48
(19,629 Views)
Which OS did you have?
Have you tried running as ADMIN?
Not sure what causing this issue but could you please share screenshots and any other relevant material that will help to check the behavior?
Try this as well
https://decibel.ni.com/content/docs/DOC-12805
Message 9 of 48
(19,625 Views)
Thanks for the answer...
My Os is Windows 7 Professional SP1 64bits.
I have exactly the same problem runing MAX as admin...
I also tried to replace the complete C:\Program Files (x86)\National Instruments\MAX directory from a computer where MAX runs... i have the same result.
Finally i tryed the MAX Database Corruption Removal Tool and i get an error when the tool tries to delete the directory C:\ProgramData\National Instruments\MAX\Data.
Message 10 of 48
(19,618 Views)
