NI Explorer 2014 USB instruments not found
NI Measurement & Automation Explorer version 14.0.0f0.
USB instruments detected by Windows Device Manager, are not found by Measurement & Automation Explorer.
Message 1 of 12
(4,416 Views)
For MAX to see them, you may need the LabVIEW-compatible Driver.  Can you tell us more about the device that MAX doesn't see?  Like its name and identifying numbers?
BS
Message 2 of 12
(4,412 Views)
LabVIEW MAX does see them on other machines.
Also, they are simple USB / RS-232 interfaces using Prolific and FTDI.
Message 3 of 12
(4,408 Views)
Do those other machines have drivers by Prolific or FTDI?
BS
Message 4 of 12
(4,405 Views)
Yes to both.
Message 5 of 12
(4,400 Views)
Sigh.  This is a slow process -- and does your machine also have these drivers?
BS
Message 6 of 12
(4,391 Views)
Yes, both machines have both drivers.
Both have current updates.
Message 7 of 12
(4,386 Views)
Sorry, that's a real puzzle!  If you figure it out, please post the solution and enlighten us -- sounds like you did all the Right Things and it Should Work (Famous Last Words) ...
BS
Message 8 of 12
(4,376 Views)
The version of MAX is irrelevant. What version of NI-VISA is installed?
Message 9 of 12
(4,298 Views)
Uninstalled all LabVIEW.
Installed LVRTE2014SP1 Run-Time Engine.
Tried running Stand alone executable (from Builder). No Luck.
Can I get MAX without Development Software?
Message 10 of 12
(4,233 Views)
