NI-DAQmx Base Error -200428
When trying to run my VI I get this error at every DAQmx:
NIDAQmx base error 200428
The error message then says:
Possible reason(s):
Value passed to the Task/Channels In control is invalid.
The value must refer to a valid task or valid virtual channels.
Task Name: QuickCapture
How do I fix this?
Message 1 of 15
(6,029 Views)
Not much information here. It's dangerous to go alone! Take this.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 2 of 15
(6,023 Views)
What other info would help here?
Message 3 of 15
(5,948 Views)
We need information pertaining to your specific subVI and/or task configuration. This error is a generic error that tells you that you didn't write the correct task to the DAQmx input, or your task isn't set up right. Without seeing what you're actally doing with your DAQmx task, that help article is the best advice that can be given when you just give us the error code.
Cheers
Message 4 of 15
(5,943 Views)
The vi is a subvi to a huge code containing hundreds of subvi's. So would it change anything if I said I only started noticing it when I added an export waveform to excel node?
Message 5 of 15
(5,930 Views)
Message 6 of 15
(5,916 Views)
First off, you're not handling any of your error clusters. Wire those puppies up so you can see if one of your DAQmx VIs throws an error.
Are you getting the error within the subVI that you shared the screenshot of, or are you seeing the error after that subVI finishes running? You have a Clear DAQmx Task VI there, which could cause trouble if you try to do other things with the task after that.
Cheers
Message 7 of 15
(5,901 Views)
It looks like the error occurs within the subvi. and at every DAQmx part of the code.
Message 8 of 15
(5,876 Views)
Well then something is happening before you get to this subVI with that DAQmx task. Are you setting up the task in MAX or are you setting it up with the DAQmx VIs somewhere else in your code?
That Task/Channels input better be getting initialized and set up somewhere else. If that's not happening correctly, then there's your problem.
Cheers
Message 9 of 15
(5,870 Views)
You are using DAQmx base? On a Mac?
Message 10 of 15
(5,862 Views)
