NI-DAQmx Base Error -200428
Looking at the image, something's not right. You have an error mentioning DAQmx Base but you are using DAQmx functions. Please clarify and attach those error clusters.
Message 11 of 15
(979 Views)
Wow, I did not know there were two different things... I thought it just meant it was a base error.
Neil, can you provide all of the code that you have that controls your DAQmx stuff? You're showing a small part of the whole DAQmx process and it's just not enough information to get to the root of the problem.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 12 of 15
(969 Views)
Gotcha. That's the problem though there are hundreds of subvi's most of which were made in 1999 and I cannot open. I tried to upscale these versions; however, it looks like they had their block diagrams removed.
Message 13 of 15
(949 Views)
What is the difference between DAQmx base and DAQmx?
Message 14 of 15
(945 Views)
This is the best explanation I could find.
Cheers
Message 15 of 15
(933 Views)
