NI 9514 Force Control
I am new to motion control in labVIEW. I have Voice coil actuator I am trying to control using a load sensor as an analogue feedback.
And this thread:
http://forums.ni.com/t5/LabVIEW/Closed-loop-control-in-force-How-to/td-p/1449700
I have tried to follow what this person did in their example. But I could not get it to run due to issues with configuring the FPGA reference for the NI 9237. So I modified the approach slightly with two FPGA vi's one filling the data buffer and one for the servo interface but I still modified the PID input to use the analogue input and not the encoder. I get the -63195 error when I run the RT code.
I attached my code for reference.
Has anyone gotten an application like this to work? Or is there a simple way to perform open loop control with the NI 9514? From what I have read it didn't look like the NI 9514 is readily setup for open loop control.
Message 1 of 9
(4,523 Views)
Hi trevorlujan, have you seen this KB yet?
http://digital.ni.com/public.nsf/allkb/CB82AC9CBC6C3F2386257241007A06EF
Angela L.
Message 2 of 9
(4,461 Views)
Yes I have checked that setting as well as the changing the LabVIEW.ini file and reloading LabVIEW.
If I didn't mention I am working in LabVIEW 2013 currently.
Message 3 of 9
(4,450 Views)
What were the FPGA errors you were running into when trying to configure the FPGA reference for the NI 9237?
Angela L.
Message 4 of 9
(4,432 Views)
None the FPGA reference compiled the only error I got was the one I mentioned previously.
Message 5 of 9
(4,418 Views)
 Is there a way to directly control the voltage output from the NI 9514?
Message 6 of 9
(4,412 Views)
It is possible, but not recommended because you will have to bypass the SoftMotion position loop.
Message 7 of 9
(4,392 Views)
Is there any documentation on writing custom control loops for the NI 9514?
Message 8 of 9
(4,389 Views)
Hi trevorlujan,
Please check your inbox - I just sent you a direct message.
Message 9 of 9
(4,385 Views)
