NI-9220 not visible in DAQ Assistant
I have NI-9220 voltage in module in cRIO-9047 controller.  NI MAX shows NI-9220 in slot 2, but DAQ Assistant does not show this device.  Please help.
(2,321 Views)
DAQ Assistant is an Express VI for the DAQmx drivers.  Things like a cDAQ chassis use DAQmx.
If you are using a cRIO, you need to setup a cRIO project since it is an FPGA device.
(2,316 Views)
Accepted by crispitn
Did you drop the DAQ Assistant on a VI that is under the target in your LabVIEW project? If you have the DAQ Assistant under My Computer, you will not see your remote modules; the DAQ Assistant will only show you modules for the target on which the VI is set to execute.
Donovan
(2,269 Views)
That worked.  Thank you, Donovan.  Saved me a lot of time.
Taeho C.
(2,244 Views)
