I made a post on this in the Public Beta boards a few months ago related to LabVIEW 2024Q3 and this "preview feature", but didn't get any response:
https://forums.ni.com/t5/LabVIEW-Public-Beta-Program-in/NET-Core-Constructor-Issues/td-p/4414018
So, with the release LV 2025 Q1, I thought I'd give this another try and see how things were, and I still had quite a few issues, such that in it's current state, this appears to be unusable :(.
In my previous post, I used an example of Microsoft Garnet, which has a fairly complex dependency chain.
For this post, I'm going to work with Npgsql -- the postgresql API, which for .NET Core is pretty simple.
Previously I've leveraged the .NETStandard2.0 version of this in LabVIEW to great success.
However, as of version 8.0 (released 11/21/2023), they no longer support anything except for .NET Core.
My process here was to download the Npgsql .dll, and the corresponding dependency dlls manually from Nuget.
These are all placed in the same folder. I create a LV project in that same folder, and a VI to work with in that same folder.
Here were my issues/observations:
I think this is a pretty simple use case, and is a representative use case of how users would want to use this (or at least it's one of the simplest use cases that I have, beyond using a single-call to a built in function.
I've attached the project here.
While normally I'd say you probably need an instance of PostgreSQL (with a populated table to test against), in this case, the code crashes while trying to make the connection, so you don't ACTUALLY need a postgreSQL instance to see everything that I've talked about in this post.
I've attached a second .zip file which has the "latest" dependencies, and exhibits the behavior of linking to the wrong .NET dll (this is labeled "LatestDependencies").
This could absolutely be a "me" problem... but if so, I'd love to know what I'm doing wrong here :).
I could also be observing a mixture of missing features/bugs, but it would be nice to know what above is a limitation vs a bug.
I'm happy to work with someone to figure this out... enabling .NET core to access various APIs is a pretty high-priority for me for some things I'm interested in.
Thanks!
Any input on this from NI support teams? Considering using .NET Core for an upcoming project and wondering what the status is of this?
I apologize for the issues that you've run into when using .NET 8 and LabVIEW. Thank you for the detailed description of the issues and the code that you've provided. The development team is investigating why LabVIEW is failing to load the dependencies properly in this case.
I've filed Bug 3008437 for this issue.
Thanks Christina for letting me know that it's being looked into!
I'm very excited to start leveraging this, so I'm happy to help in anyway I can. Feel free to reach out directly via PM if you need additional information. 🙂
My previous post (in the beta forums) had a more complex library I was working with (Microsoft Garnet), and I have a few other use cases I'm interested in testing as well!
Please forgive my ignorance if this is way off base but is this a case where a .config file (outlined in the links below) will solve the problem?
https://www.ni.com/docs/en-US/bundle/labview/page/configuring-a-net-client-application.html
The config file referenced in those articles applies to .NET framework (or specifically for use with .NET Standard). I used those regularly with those dlls to good success (and I think I referenced that either in this post, or in the one I made in the old beta forum)
This question is with regards to the new .NET Core functionality, which does not use those files (as far as I know). I confirmed with NI that what I'm observing is indeed a bug. It was partially fixed in the new 2025 Q3 Beta, but there are still some outstanding issues.
My understanding is that .NET core should be explicitly preferentially checking for libraries in the project/exe folder(s)... and it wasn't doing that.
That all said, I'm also not an expert here 🙂
I have the same problem with dll dependent on 2 other dll's
Your:
"HOWEVER -- if I first create a constructor for each of the dependencies and select a random constructor,"
Also solved it for me !
I haven't checked if .Net Core changed those conditions but in .Net Framework the only special "directories" that .Net would search by default, were the EXE directory and the GAC. Adding other directories to the search path requires to create a specific AppContext at process startup or a rather complex search path resolver. There used to be some functions that allowed to do that more easily in .Net 1.0 but they were discontinued in later .Net versions because use of that made a .Net process pretty vulnerably to all kind of attacks.
I think LabVIEW did at some point register the project directory as an additional search path but there is likely some discontinuity in .Net Core that makes this same mechanism not work in it. What definitely won't happen is that .Net will search for dependencies automatically in the directory from which an assembly is loaded. That would make it simply to easy to sideload unwanted assemblies into a process by an attacker.
Same here.
With LV 2020 .NET Standard assemblies worked with .NET Framework.
With LV 2025 .NET Standard assemblies are supposed to work with .NET Core and "DisableDotNetFrameworkSupport=True", but... error 1172.
