.NET Core in LabVIEW 2025 Q1
I made a post on this in the Public Beta boards a few months ago related to LabVIEW 2024Q3 and this "preview feature", but didn't get any response:
https://forums.ni.com/t5/LabVIEW-Public-Beta-Program-in/NET-Core-Constructor-Issues/td-p/4414018
So, with the release LV 2025 Q1, I thought I'd give this another try and see how things were, and I still had quite a few issues, such that in it's current state, this appears to be unusable :(.
In my previous post, I used an example of Microsoft Garnet, which has a fairly complex dependency chain.
For this post, I'm going to work with Npgsql -- the postgresql API, which for .NET Core is pretty simple.
Previously I've leveraged the .NETStandard2.0 version of this in LabVIEW to great success.
However, as of version 8.0 (released 11/21/2023), they no longer support anything except for .NET Core.
My process here was to download the Npgsql .dll, and the corresponding dependency dlls manually from Nuget.
These are all placed in the same folder.  I create a LV project in that same folder, and a VI to work with in that same folder.
Here were my issues/observations:
  • The issue of not being able to create .NET Core constants (by right clicking on a .NET Core reference constant, and trying to change the class) now works -- this did not work in the Preview -- Yay!
  • If I just right-click the constructor, click "Select .NET Core Constructor", and browse to the Npgsql.dll, I can see the classes/objects, but if I click on one, I get no "Contructor".  This includes NO "There are no available constructors" messages.  It's just blank.  This is unhelpful.
  • HOWEVER -- if I first create a constructor for each of the dependencies (in this case: Microsoft.Extensions.DependencyInjection.Abstractions, and Microsoft.Extensions.Logging.Abstractions) and select a random constructor, I now see things loaded as expected, and I can select the class to work with (yay!), so it appears that dependencies are not being found auto-magically if the dlls are all in the same folder (which is how .NET Framework works)
  • I also ran into one other weirdness with the dependencies.  If when I went to download things, I downloaded the absolute LATEST dependencies (v9.0.X) -- (Note this is still the .NET Core 8.0 runtime not the new 9.0... just the package version is 9.0)  -- And I go through this same process, npgsql will no longer work.  This APPEARS to be because a new dependency (System.Diagnostics.DiagnosticSource.dll) is added in this version, and the system auto-links it to the version installed to the OS, which is a version 8.0.X, and hence incompatible.  I can't force it to relink to the correct later version.
  • Going back to a working version... while trying to actually work with the libraries, I CONTINUALLY got pop-ups telling me that it was seeing a library version change from 0.0.0.0 --> 9.0.2.  This was happening pretty much anytime I moved a node, selected a function, tried to wire something, went to run the VI... anything... once I got sufficiently many nodes dropped down, this because almost unrealistic to work with because of all of the pop-ups (a run/save/compile/LV Restart did not change this behavior).
  • After I got things started up I tried to establish a connection to the postgresql data source.  I ran the code and got a lovely pop-up telling me there was an arbitrary error, but no actual error information was sent out.  Compare this error message, to the one from the same calls in the older .NET Standard 2.0 API from LV 2020 (second image) which is nice enough to tell me that I had an error in my connection string related to the "user" entry.
  • Once I fixed this error on my side, and I ran the code again... I got a hard crash in the "Open Connection" command.  By hard crash, I mean that LabVIEW just completely shutdown, with no messages what-so-ever, and when I start it back up, I also get no messages.  However, the crash does show up in the Windows Event Viewer, with the following information, saying that the niDotNETCoreInterop.dll was the cause of the crash -- (note, this same calls does NOT crash LV 2020 with the .NET Standard 2.0 version of the library)
I think this is a pretty simple use case, and is a representative use case of how users would want to use this (or at least it's one of the simplest use cases that I have, beyond using a single-call to a built in function.
I've attached the project here.
While normally I'd say you probably need an instance of PostgreSQL (with a populated table to test against), in this case, the code crashes while trying to make the connection, so you don't ACTUALLY need a postgreSQL instance to see everything that I've talked about in this post.
I've attached a second .zip file which has the "latest" dependencies, and exhibits the behavior of linking to the wrong .NET dll (this is labeled "LatestDependencies").
This could absolutely be a "me" problem... but if so, I'd love to know what I'm doing wrong here :).
I could also be observing a mixture of missing features/bugs, but it would be nice to know what above is a limitation vs a bug.
I'm happy to work with someone to figure this out... enabling .NET core to access various APIs is a pretty high-priority for me for some things I'm interested in.
Thanks!
Message 1 of 9
(4,158 Views)
Any input on this from NI support teams? Considering using .NET Core for an upcoming project and wondering what the status is of this?
Message 2 of 9
(4,038 Views)
I apologize for the issues that you've run into when using .NET 8 and LabVIEW. Thank you for the detailed description of the issues and the code that you've provided. The development team is investigating why LabVIEW is failing to load the dependencies properly in this case.
I've filed Bug 3008437 for this issue.
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 3 of 9
(3,951 Views)
Thanks Christina for letting me know that it's being looked into!
I'm very excited to start leveraging this, so I'm happy to help in anyway I can.  Feel free to reach out directly via PM if you need additional information. 🙂
My previous post (in the beta forums) had a more complex library I was working with (Microsoft Garnet), and I have a few other use cases I'm interested in testing as well!
Message 4 of 9
(3,940 Views)
Please forgive my ignorance if this is way off base but is this a case where a .config file (outlined in the links below) will solve the problem?
https://www.ni.com/docs/en-US/bundle/labview/page/loading-net-20-30-and-35-assemblies-in-labview.htm...
https://www.ni.com/docs/en-US/bundle/labview/page/configuring-a-net-client-application.html
Message 5 of 9
(3,187 Views)
The config file referenced in those articles applies to .NET framework (or specifically for use with .NET Standard).  I used those regularly with those dlls to good success (and I think I referenced that either in this post, or in the one I made in the old beta forum)
This question is with regards to the new .NET Core functionality, which does not use those files (as far as I know).  I confirmed with NI that what I'm observing is indeed a bug.  It was partially fixed in the new 2025 Q3 Beta, but there are still some outstanding issues.
My understanding is that .NET core should be explicitly preferentially checking for libraries in the project/exe folder(s)... and it wasn't doing that.
That all said, I'm also not an expert here 🙂
Message 6 of 9
(3,183 Views)
I have the same problem with dll dependent on  2 other  dll's
Your:
"HOWEVER -- if I first create a constructor for each of the dependencies and select a random constructor,"
Also solved it for me !
Message 7 of 9
(3,059 Views)
I haven't checked if .Net Core changed those conditions but in .Net Framework the only special "directories" that .Net would search by default, were the EXE directory and the GAC. Adding other directories to the search path requires to create a specific AppContext at process startup or a rather complex search path resolver. There used to be some functions that allowed to do that more easily in .Net 1.0 but they were discontinued in later .Net versions because use of that made a .Net process pretty vulnerably to all kind of attacks.
I think LabVIEW did at some point register the project directory as an additional search path but there is likely some discontinuity in .Net Core that makes this same mechanism not work in it. What definitely won't happen is that .Net will search for dependencies automatically in the directory from which an assembly is loaded. That would make it simply to easy to sideload unwanted assemblies into a process by an attacker.
Rolf Kalbermatter  My Blog
Message 8 of 9
(3,042 Views)
Same here.
With LV 2020 .NET Standard assemblies worked with .NET Framework.
With LV 2025 .NET Standard assemblies are supposed to work with .NET Core and "DisableDotNetFrameworkSupport=True", but... error 1172.
Message 9 of 9
(1,632 Views)
