08-10-2009 01:26 PM
I have just installed NI-DAQmx 8.8 in my Windows XP running on Mac for plugging NI-USB 6009 device, but under the Measurement and Automation window, I can't see any device name under Devices and Interfaces<NI-DAQmx Devices. The green LED of the device is continuously blinking while I connect it to the USB port. I will really appreciate if somebody has any clue to solve it.
-Medhi
08-10-2009 01:32 PM
Can you see it as a VISA instrument?
A USB device will show up as a COM port.
Just place a VISA constant on your block diagram,
then press the arrow for the drop-down box and it should show up.
08-10-2009 04:04 PM
If you can't see it in MAX, you will not likely see it in LabVIEW.
Have you plugged in the device after booting to WinXp? It should say that it found a new hardware.
After getting the message, have a look in MAX. It should be listed.
However, I have not tried the more recent DAQmx drivers..
RayR
08-11-2009 10:18 AM
08-11-2009 11:33 AM
08-11-2009 12:22 PM
08-11-2009 01:49 PM
Medhi,
When you plug the device into your computer, does Windows bring up the Found New Hardware Wizard? If it does, then you need to let this run to associate the proper drivers with the device. If it does not come up, then you may need to Scan for Hardware manually in the Device Manager to find the USB 6009. If it is not showing up in Device Manager, then it will definitely not show up in MAX.
Do you have NI-VISA installed? The USB 6009 should show up under NI-VISA USB Devices in the Device Manager.
-Christina
08-11-2009 01:50 PM
Have you checked to see if MAX recognizes it?
I don't think Windoze will populate the device manager for a USB DAQmx device. Maybe I should try it tonight... I'm curious.
What is important is if MAX detects it.
08-11-2009 02:32 PM - edited 08-11-2009 02:33 PM
08-11-2009 02:49 PM
Medhi wrote:
Unfortunately it is in windows. Windows doesn't recognize the device. I don't know, is this a problem because of running WinXP in Mac?
That may well be the problem.
