mixed signal graph in labview 7.1
 I needed to use the VI which was created for the cylinder measurements in
LABVIEW version 8,0.. And I have only the version of  LABVIEW version 7.1
when i got it converted to LABVIEW 7.1, the converted VI showed  'the mixed
signal graph'does not exist in this version..help in getting it replaced with alternative
arrangement..
 I Have added the attachments which was in version 8.0 and 7.1..And
Thanks in Advance....
RAMSO
P.S: the DAQ is not being shown being shown..please add them
the analog inputs would be 1. crank  2.trigger(TDC)   3.pressure
Message 1 of 9
(3,441 Views)
Use a regular graph.
Your question about DAQ does not make any sense. All of the data is simulated. If an actual DAQ card is going to be used, that is a modification you should make yourself.
Message 2 of 9
(3,437 Views)
HELLO
 1.When, I am substituting Mixed signal graph with a normal graph, It is showing an error in the VI,
  2. Can use 3 DAQ for 3 analog inputs.As in the VI
Please do the necessary changes..
Message 3 of 9
(3,429 Views)
Your VI doesn't show any DAQ functions at all.
We are not a code writing service for you so we can't "please do the necessary changes".
This is your project, so you need to be the one who programs it.Smiley Frustrated
Message 4 of 9
(3,427 Views)
Ok..
Then what is the means to get 3 waveforms simultaneously in Version 7.1..(replacement for mixed signal graph)
can I use 3 daq for 3 analog input..
I am getting the error when replaced with other graphs....
Message 5 of 9
(3,424 Views)
Use A REGULAR GRAPH! We are not mind readers. How can anyone know what kind of error you have.
Use one DAQmx Read to get 3 signals.
Message 6 of 9
(3,413 Views)
Hello
  please check the VI,(LabVIEW version 7.1)
.  1. I had added wave graph.But was not getting the output in graph..
   2. Getting 2 signals in the notepad.The third signal is missing (sinusoidal waveform).
   3. Can I use 3 DAQ as analog input in this VI...
Thanks in advance
Message 7 of 9
(3,400 Views)
Sorry, VI for above..
P.S:A replacement for multisignal graph in 7.1
Message 8 of 9
(3,399 Views)
That VI has no graph and is in LabVIEW 2011. What sort of games are you playing?
Message 9 of 9
(3,390 Views)
