My LabView file does not work after I convert it to an application (exe) file
ramair wrote:
Broken Arrow,
The 14 channels are assigned to SCXI-1102B which has 32 channels. I am not using SCXI-1124.
It's odd - on my computer, where I have a SCXI-1102, it assigned those 14 channels to the my 1124. Sorry for the unrelated tangent.
Richard
Message 11 of 12
(515 Views)
A debuggable executable is a good idea.
Is this executable running on the same PC as your development environment or a different PC?
I'd recommend putting some error indicators in there such as on your DAQ assistant and other express VI's.
One thing I'd worry about is that you are trying to collect 1 sample every 100 milliseconds.  By having the File writing VI's in there also, you might get to a point where you loop runs slower than the data acquisition and you start filling up your acquisition buffer.  There are also opportunities for race conditions by the use of the value property nodes being read from and/or written to in parallel at multiple locations.  There is also a lot of replicated code in the top half of your VI that should be placed in a subVI.
Message 12 of 12
(501 Views)
