Multitask DAQmx
Thank you so much for your help.
My last question is: If I have one task to read both and log everything,  My first block is DAQmx create channel and the second is the time. Then My doubt is:How I can  separate two signals in DAQmx?
Thank you.
Pedro
Message 11 of 14
(1,918 Views)
Thank you.
Pedro
1. You will need a second DAQmx Create Channel with the task created from the first one passed into the second and then progress into the timing.
2. When you do the DAQmx Read, just use Index Array to seperate the channels.
Message 12 of 14
(1,896 Views)
The code will be like the code I attached .
Thank you.
Regards.
Pedro
Message 13 of 14
(1,887 Views)
1. You do not need to configure the digital trigger line.  This task is to log everything.
2. The Index Array is expandable with the first output defauting to the first element and then incrementing elements from there.
3. You should not clear the task until the loop is complete.
Message 14 of 14
(1,875 Views)
