Multiple waveform charts "stacked plots" with limits
Hi everyone Smiley Happy
Here is my problem, currently i have 4 waveforms "attached" together with the "Build Array" function and connected to a waveform chart.
I use the option "stacked plots" in order to have 4 curves with only one x-axis.
What I want to do is to add for each curve an upper limit line.
Thank you very much in advance for your replies!
Message 1 of 11
(3,782 Views)
Hello Rafale,
Maybe a question out of the box:
Do you want the current maximum of the signal?
Or do you just want to show a line which you should not go above?
In the latter case: Is this Upper Limit fixed (during your measurements)?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 11
(3,753 Views)
Hello ThiCop! Smiley Happy
Yes, I want to show a line which we should not go above and yes this limit is fixed during our measurements.
(I receive the value of the measure and its upper limit by TCP / IP)
Thank you for your reply!
Message 3 of 11
(3,746 Views)
Hi rafaele,
add 4 more plots to your chart to show the limit lines...
Message 4 of 11
(3,742 Views)
Hello Rafal,
As you probably noticed in my other post I like to have all background information.
I'll do the same here, but I'll also give you first a relatively simple solution.
If you have a Graph (and not a Chart), then you could just use Cursors to do this and everything would be fixed.
Seeing that you're not using a Graph, you can add an extra data set (with the constant Maximum) that you also write to your Chart. (see Gerd 😉 )
Or you could use a Graph and its Cursor Functionality and make it behave like a Chart.
There are several options, but to have a better idea at what might be best suited, it might be interesting to have a complete overview of how your application works.
Does your TCP/IP communication send the maximum/boundary and all the data at once?
Or do you really want to see each new data sample that appears on the TCP/IP "input"?
Kind Regards,
Message 5 of 11
(3,741 Views)
Hi GerdW,
If I do this, the limit lines will be displayed on separate graphs and I will have 8 waveform charts ...
Thanks.
Message 6 of 11
(3,733 Views)
Hi ThiCop, Smiley Happy
The measurements are performed continuously and the goal is to display the current and former values of measures taken over a period of two weeks and that's why I use chart and not graph.
An other computer sends measurements to my VI every 2 minutes and possibly the new upper limit if needed, these informations are then placed in a queue.
I use chart in order to avoid the management of buffers. I prefer to have 4 separate waveform charts with their upper limits that having to manage buffers.
Thank you again for your reply.
Message 7 of 11
(3,728 Views)
Hi rafaele,
nothing comes for free! The chart is provided as is...
Your next best option is tu use 4 charts instead of just one with stacked plots. Hide the x axis for 3 of them and display 2 plots each...
Message 8 of 11
(3,725 Views)
Hi Gerdw,Smiley Happy
Ok thanks! I will use 4 separate waveform charts, it's a bit unfortunate, it would have been "nicer".
I've already tried to hide the x-axis of 3 waveform charts and then superposed them, but it's not very "pretty".
Message 9 of 11
(3,716 Views)
Accepted by rafale350
Hi rafaele,
use the charts from classics palette. Make their border/background transparent and use a decoration as "border" for all 4 of them...
Message 10 of 11
(3,711 Views)
