Multiple analog inputs with different configuration RSE/Differential
Hi
Can anyone advise how to measure two analog inputs with different configurations using a USB 6009?
I am aware of the syntax to create to virtual channels for the DAQmx Create Virtual Channel(s) so I have created two channels using Dev3/ai0:1 but I would like the first channel to be RSE and the second to be Differential.
So far I have not found any way to specify the configuration for the separate channels.
Any ideas much appreciated!
Jack
(3,859 Views)
Have you tried this??
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,844 Views)
Hi
Thanks for the response.
I have just tried as you suggest using the DAQ Assistant (creating two channels and setting the configuration differently) and this seems to work.
I prefer to use the 'low' level vi's so still curious to know if there is a way to set the configuration using them.
Cheers
Jack
(3,840 Views)
Accepted by JackT
It should be like this:
(3,835 Views)
Great!
Thanks for the advice.
(3,832 Views)
Well, you can always skip the very first node (which is DAQmx Create Task.vi), I just kept it for elaborating the concept.
(3,829 Views)
