Multiple Choice Quiz
I'm very new to LabView, so forgive me if my question seems overly simple. I'm trying to incorporate what basically ammounts to a multiple choice quiz into my front panel VI. I want the user to choose one of the answers provided, and then have it move onto the next question, and repeat the same process. I also need the ability to log which answers are chosen for which questions. I think I have a basis to do this, but I am just not familiar enough with this program yet to grasp the finer points. So far I have four buttons, each linked to a local varriable. I have a while loop, and the counter i is linked to another local variable that keeps track of which question the user is on. I know that I will need to use the "Write Labview measurement file" to save the data, but I'm not sure how to work it to do what I want. The "Build Text" function looked like it might do what I want in terms of interpreting data, but again, I must be doing something wrong. Also, I'm not sure how to make it so that after the user answers one question the text that asks the question is changed. Any help or hints in any of these area's would be greatly appreciated.
Message 1 of 16
(12,871 Views)
Attached is a quick vi that shows one way to accomplish what you're trying to do. There is an input array of questions and an output array which are the answers given. This will step through all of the questions sequentially. I have also graded the test by comparing to a list of correct answers.
All of this information can be stored to file at the completion of the test. You may also log the data during the test, one line at a time.
Message 2 of 16
(12,853 Views)
Thanks, I'm sure that will help, but I only have version 7.0 and it won't let me open the VI
Message 3 of 16
(12,849 Views)
Accepted by wiebe@CARYA
Here it is in version 7.0.
Message 4 of 16
(12,846 Views)
Here is a anothe rexample
Joe.
"NOTHING IS EVER EASY"
Message 5 of 16
(12,841 Views)
Excuse me, i've opened multiple choice.vi but the there are no question ( empty box )
should i write my own question or the question are already exist ?
Message 6 of 16
(10,306 Views)
in the first vi (i didn't open the 7.0 version though) there are questions,
the questions field gets populated in each iteration of the for loop from the auto indexed "Array of Questions"
the event structure inside the for loop listens on "mouse up" events on each answer button
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 7 of 16
(10,292 Views)
I'd use either a cluster with four buttons or a radio button with 4 buttons (set to allow no selection).
Typically, you'd use the event structure to detect value changes (regardless what's used: 4 buttons, a cluster or a radio button). No need for local variables.
I would not use that. Don't think I ever used it.
This kind of information would be ASCII, and I'd want the resulting files to be readable in e.g. Notepad.
I'd use the Config File VIs library (under File I\O). Although a bit primitive, that library takes a lot of work out of your hands...
That's an architecture problem. I'd make a loop with an event structure in it. For this problem that would be enough. You might also look into state machines and\or producer\consumer architectures.
If you post what you have, we can help you better.
Message 8 of 16
(10,283 Views)
Oh, and consider upgrading. LV7 is 11 LabVIEW versions old.
Message 9 of 16
(10,282 Views)
i want make quiz like " who wants to be a millionaire " where each answer button has text, and one of them is correct answer, when the question changes, text on the question button change as well.
anyone can help me ?
Message 10 of 16
(10,279 Views)
