Nested case structure problem
So I'm a new user and I wanted to make four cases using a nested case structures. So I am selecting cases from two combo-boxes each having two options. But when I run the program, the outer case executes just fine while the inner case just executes default cases for each of the outer cases. Is there a way to make this work?
(2,976 Views)
Accepted by topic author singh530
Hi singh,
Sure there is!
Why do you need nested case structures?
Why do you use comboboxes?
Why don't you use a single case structure with 4 cases?
Why don't you attach your code when you have problems with your code? (Keep in mind: we cannot run/edit/debug images with LabVIEW!)
(2,972 Views)
He did attach the code.
You compared e.g. "Litz " with "litz". Both capitalisation and a space makes the comparison fail.
Certified LabVIEW Architect
(2,934 Views)
Note: You can right-click on a case structure and select "Case Insensitive Match"
(2,917 Views)
You can right click on the case structure and choose "case insensitive match" in order to eliminate the capitalization issue. That won't fix the space issue but it at least fixes that.
Another option is to use an enum instead of the combo box.
(2,912 Views)
If you don't actually need to write into the combo-box, you could use a ring, set it to DBL type, and edit the values. Then you can get rid of the case structures since the value is connected to the selected item:
(2,899 Views)
