Multiple ActiveX Containers
I'm trying to open 3 Separate PDF files within a LabVIEW front panel.  For some reason, I can only get 2 of the ActiveX containers to show the PDFs.  The 3rd one, 2nd one in the block diagram sequence, just shows a white background and never displays the PDF.
Does anyone know why this might be? I've attached the block diagram.
(2,896 Views)
What happens if you do NOT close the ActiveX ref?
Ben
(2,787 Views)
I think i figured it out:  All i did was add a 500msec delay after closing an ActiveX reference and before opening the next one.  In this case, the extra time isn't too critical for the end use.
Not sure if there's a better solution to this.
(2,374 Views)
